On the 2100S sheet I have from November 1953, the parts list shows part 61-431 Upper Pump Spring (outer) and 61-432 Upper Pump Spring (inner), in addition to 61-510 Pump Diaphragm Spring, which should be the big lower spring. This is the only 2100S sheet I have, so I can't speak on design changes/updates.
Maybe Carbking will chime in at some point with an expert opinion.
There is a 1957 2100s document I got about 7 years ago...can't find it right now. It was an update to the 1953 document and I can't offhand remember but I suspect it may show any revision. Will keep looking. In the meantime, here is an image of the upper springs I removed from one to help me remember...2 springs. Carbking will know.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
