| | | Forums66 Topics128,026 Posts1,055,410 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2016 Posts: 61 'Bolter | | 'Bolter Joined: Sep 2016 Posts: 61 | I have a 1950 chevy 1300, what is the gasket called that is in the exterior door side of the window and is mounted in a channel below the window opening, it’s like a sweeper for the outside of the window and helps prevent water from water pouring into the door, also where can I get a replacement? | | | | | Joined: Sep 2009 Posts: 5,777 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,777 | dogdaddy, Most commonly known as "outer door window seal". This one fits your 1950 doors Outer door window seal, assuming they are the originals with one piece glass (no vent window). BTW - Your previous posts indicated you asked questions about a 1949 3100 with lift bed, then a 1948 truck and looking to replace cab with a 1952 5-window. Interested to see pics of the 1950 1300 (or is it a 3100?) that you mentioned having now.  Dan PS - I removed your duplicate post on the same topic from the General Truck Talk forum. Now that you have the part ID'd, suggest further questions on the door and window topic would be better asked in the Paint and Body Shop forum.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Sep 2016 Posts: 61 'Bolter | | 'Bolter Joined: Sep 2016 Posts: 61 | Thanks for the guidance and link, appreciate it | | | | | Joined: Sep 2009 Posts: 5,777 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,777 |
