0 members (), 108 guests, and 2 robots.
Topics128,035
Posts1,055,560
#1518828 09/23/2023 7:30 PM
I have a 1950 chevy 1300, what is the gasket called that is in the exterior door side of the window and is mounted in a channel below the window opening, it’s like a sweeper for the outside of the window and helps prevent water from water pouring into the door, also where can I get a replacement?
dogdaddy #1518836 09/23/2023 8:17 PM
dogdaddy,
Most commonly known as "outer door window seal".
This one fits your 1950 doors Outer door window seal, assuming they are the originals with one piece glass (no vent window).
BTW - Your previous posts indicated you asked questions about a 1949 3100 with lift bed, then a 1948 truck and looking to replace cab with a 1952 5-window. Interested to see pics of the 1950 1300 (or is it a 3100?) that you mentioned having now. headscratch
Dan
PS - I removed your duplicate post on the same topic from the General Truck Talk forum. Now that you have the part ID'd, suggest further questions on the door and window topic would be better asked in the Paint and Body Shop forum. wink
~ Dan
1951 Chevy 3 window 3100
Gdads51 #1518842 09/23/2023 8:48 PM
Thanks for the guidance and link, appreciate it
dogdaddy #1518854 09/23/2023 10:08 PM
thumbs_up
~ Dan
Moderated by  klhansen, Rusty Rod
