1 members (lumbersawyer),
84
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2023 Posts: 118 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 118 | I'm asking the members of this forum who live in Myrtle Beach or Little River South carolina if they do or know of anyone who does body work on the side? My brother has a 1950 3100 he's trying to restore by himself but is running into issues getting it ready for primer. He is hand sanding the entire truck but it has several coats of paint. And can't seem to get it smooth. Any help or leads will be appreciated. Thanks
1950 chevy shortbed 3100, 216 with a 3 on the tree.
| | | | | Joined: May 2015 Posts: 11,040 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,040 | What's your brother using to sand it? A DA power sander is fast, but won't always get it smooth, and it may be necessary to remove all the old paint and start from scratch. A DA sander with coarse enough disks WILL remove the old paint, which may be the best approach. The multiple layers of paint probably have different hardness and the transition between layers may always show up, although priming and block sanding will eventually cover those up. Once it has primer on it, a long block for hand sanding is the way to go.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Just personal thought but old vehicles with many repaints should be stripped to bare metal. Soda blast or sand blast are quickest but chemical does a good job but slower. Each has good vs less than good aspects. Paint now is much better than it used to be but prep is very important to make it really holdup. Good luck... | | | | | Joined: May 2015 Posts: 11,040 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,040 | X2 to what vettecrazy said. I had most of my truck blasted. And it was just a couple coats of old paint. My main reason was to get rid of the rust though.
