Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 64 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
#1518567 09/21/2023 10:16 PM
After two days I have pilot bearing in so ready to move to the clutch. But I wanted to be sure of the torque values I looked up.
Flywheel 60
Pressure plate 45.
Doug
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
T-Doug #1518605 09/22/2023 2:00 AM
The 48-51 shop manual says 50-65 for the flywheel and 25-30 on the clutch cover to flywheel
Should be the same for your 54.
T-Doug #1518608 09/22/2023 2:08 AM
Doug,
I just posted a reply in your Project Journal thread. Identical to what Kevin posted above.
Dan
~ Dan
1951 Chevy 3 window 3100
T-Doug #1518621 09/22/2023 5:34 AM
The 55 second Series shop manual calls for 55-65 ft-lb for the flywheel. Can't find the pressure plate specs in there though.
T-Doug #1518640 09/22/2023 1:49 PM
Thanks for the feedback everyone ... I'll go with 60 on the flywheel and 35 on the clutch.. 5 lb shouldn't be that big a factor..
I have a 54 1st shop manual and I couldn't find any torque specs for these.. they are usually listed on the last page of each section but weren't in the clutch section..
Doug
1954 Chevy 3100
Montgomery, AL
In Project Journals
