2 members (216wny, Hotrod Lincoln), 68 guests, and 2 robots.
Topics128,036
Posts1,055,458
Members48,422
#1518388 09/20/2023 7:50 PM
The outside of the HB has a worn area around it. Windering what could cause that, is there something I don’t see?
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
If you mean on the outside of the snout that goes into the engine, that's wear from where the timing covers seal runs. Get a speedi-sleeve to repair that. I think they're available from RockAuto (you'll need the engine and probably what it came from to get the right size.)
SEAL WEAR
glennj3 #1518489 09/21/2023 12:36 PM
Any 194, 230, 250, or 292 will use the same size repair sleeve, years won't matter. Suspect some V8 Chevrolets use the same one also.
glennj3 #1518490 09/21/2023 12:52 PM
Glenn,
Here is a link to the Repair Sleeve you need.
If you don't want to order from rockauto, you can use the part numbers/manufacturer info to go to your local FLAPS to purchase this commonly available item.
Dan
~ Dan
1951 Chevy 3 window 3100
Looks like it may have been sleeved once already.
