2 members (cmayna, Gray_Ghost), 168 guests, and 0 robots.
Topics128,114
Posts1,056,613
Members48,450
I seemed to have misplaced a rear shock bracket that bolts to the frame cross member support. I only had one, because the second one was missing. Couldn’t find reproductions on various web sites. I’m guessing that I’ll fabricate a pair.
Can anyone assist me with the thickness of the bracket and the offset angle measurements?
-Mike
1955 Chevy 2nd Series 3100 Stepside, 235cid
Give All American Classics inc. a call.
All american classics
I just pulled my rear axle last night. I will get you pics/dimensions this afternoon.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I didn't pop the rivets, so I don't know the ID of those holes and my mount hole at the top has been drilled out for bolts, so I have no idea if it is correct or not.
It is currently 5/8", but don't assume that is right.
Let me know if you need sny other dimensions.
Drawing
Mounting
Side view
I forgot about All American Classics. Thanks for the reminder! Just added them to my list of favorite web sites. I will reach out to them.
Thanks for the photos and sketch. It’s perfect for what I’ll need if I have to fabricate a pair. The bracket that I had or have somewhere, was bolted on and the holes where the rivets used to be measure 3/8”.
Not sure the reason, but there was no floor in the bed of this truck and the cross member where the upper shock brackets mount is a bit mangled and has other pieces of steel welded onto it. I ground off the rivets, removed the cross member and had a replacement cross member fab’ed up at Metal Supermarkets for $47. The rebuilding continues!
Thanks again,
-Mike
I corrected the hole diameter above. I copied from my notes wrong. The shock pin hole is 5/8" diameter, which appears to be correct for the GM pin that goes into it.
Gabriel Shocks (82060) come with a new pin, for what that is worth.
I wanted to say here it is.. But on the 2nd series, it does not show. I bought one for my 54 first. At one time I had both and lost one and wanted to put the shock back to the original configuration. The story is on here somewhere. Best of luck.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
