7 members (MickeyP, RoadsScholar, fonz8261, 37 GC, Otto Skorzeny, Biermann, Hugh63c10),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,147 Posts1,056,805 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 5 Junior Member | | Junior Member Joined: Mar 2007 Posts: 5 | And I've got a lot of questions. While gathering lots of scrap steel, old farm equipment and such, out of our field, we came upon this truck. The Good: The cab is good and strait, the engine, tranny, front and rear axles are all here. All the glass is good and in place, as is the grill, and the headlights. The Bad: The fenders are cut up. The frame from the cab back has been cut off to make a trailer, many years ago, although the original flatbed is still there. Here\'s a good shot. The rest of the pics are here. First of all, how do I find out if the truck is a '39 or a '40? Once I get this thing out of the woods, what are some other things I should look for. Any other facts about these trucks, how many made, what engine, tranny, rearend, etc. I would love to restore this truck, but I already have too many projects in the works. This truck will either be sold as is, parted out, or sold for scrap. Right now though I just need some more info on it. Any help or information about these trucks would be greatly appreciated. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Sorry I can't help ID the year, it's before my preferred era. It will make some nice parts for those with those relatively rare COE's. Too bad someone took a torch to it, Scott | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ArBlaZeR2, I'm pretty sure it's a 39, it should have a 216 Chevy engine and 4 speed trans, as for the resto prospect as long as the frame is still under the cab, the parts that are cabover peculiar can be transfered to another chassis, hope that helps. | | | | | Joined: Mar 2007 Posts: 5 Junior Member | | Junior Member Joined: Mar 2007 Posts: 5 | Thanks for the help 3B. Anybody else know anything? | | | | | Joined: Dec 2006 Posts: 184 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 184 | It definitely appears to be a 39. The top bar of the grill is narrow. 40's are about an inch deeper. The 39's are rarer than the 40's in terms of production numbers. I did a check and this would be a rare truck, whatever configuration it ultimately was. According to my calcs (if I can still add right) there were a total of 4239 COEs total made in 1939. By comparison there were about 11,000 three quarter ton pickups alone built the same year. Early Chevy Production Numbers This truck is worth keeping just because the trim is relatively intact. Sheet metal can be fixed, frames can be found, 216's are everywhere, but the trim is the impossible stuff to find - especially that grill. Some other things to keep in mind. The carb for a COE is supposed to be an updraft carb (fussy at best). 216 was the only engine Chevy made and if the engine is in it check for the following casting numbers to see if it original: Block Casting Number 838941 Head Casting Number 838773 That would add to value as a restorer. Good luck. 39's are the best! (okay i'm biased) If I think of anything more, I'll post it. | | | | | Joined: Mar 2007 Posts: 5 Junior Member | | Junior Member Joined: Mar 2007 Posts: 5 | Thanks, that's exactly the stuff I needed to know! | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | There should be an ID plate on it; 39 COE truck models VE, VF,VG, VH, VM or VN. 1940 models were the same but W instead of V.
34 & 35 trucks are the greatest
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | | | | | | Joined: Apr 2006 Posts: 3 Junior Member | | Junior Member Joined: Apr 2006 Posts: 3 | hello there are some nos fenders on the bay at the moment, expensive.... but nice | | | | | Joined: Dec 2006 Posts: 184 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 184 | Originally posted by 35 trucker: There should be an ID plate on it; 39 COE truck models VE, VF,VG, VH, VM or VN. 1940 models were the same but W instead of V. On the non-COE's the ID plate is located on the passenger side of the cowl under the hood. Not so sure on a COE, but you might look in the same general location. Some things to know about the serial number. 1st number: Assembly location - other resources on site have what the various plants are. 2nd two letters: Truck ID per the quoted portion above. Next 2 numbers: Month in the previous year that it was assembled. Last digits: What number this truck was off the line. This will also help you establish the rarity of the vehicle. If you find the VIN number post it, and several people can help you decode it. What a cool truck. | | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Did you bring jumper cables? | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Man . . . a pre-40s COE . . . I think I can count the times I've seen one on one hand. Very cool.
And what's with the spot-light in the middle? Typical for delivery trucks, maybe?!
-Michael | | | | | Joined: Mar 2007 Posts: 3,433 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,433 | Don't cut it and don't scrap it, they just don't build these things anymore. There is someone out there looking for just what you have. Post it on ebay and the swap meet here. I'm sure the word will get out that you have a rare find. Someone wants this truck.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Wow is that ever neat. I had no idea that they used torque tubes on heavy trucks. When did that stop? | | | | | Joined: Dec 2006 Posts: 184 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 184 | Finally looked at the entire web album. The round gauges again confirm a 1939 truck. | | | | | Joined: Mar 2007 Posts: 5 Junior Member | | Junior Member Joined: Mar 2007 Posts: 5 | Thanks guys. I won't scrap it. Tomorrow I plan on going up there and pulling it out into the open, put the tires on it, and check all the numbers.
Then I'll probably post it up for sale, although I have no idea, what to do ask for it. | | |
