6 members (NJC, Gdads51, joe apple, 3B, 3800GUY, 1 invisible), 83 guests, and 1 robot.
Topics128,130
Posts1,056,367
Members48,441
#151748 03/29/2007 3:47 AM
Apprentice
Apprentice
Fellow Big Bolters,
I'm looking for a good supplier for 7.50 x 20 tires. Right now I'm in need of 4 to get my 4400 on the road. Any suggestions?
Cartman
#151749 03/29/2007 5:24 AM
3B Online: Content
3 Online: Content
Hy Cartman, Have you tried Goodyear, it's been awhile, but that's were I got my last set from, hope that helps.
#151750 03/29/2007 4:53 PM
You can also try Tucker Tire.
http://www.tuckertire.com/
~Ron
#151751 03/29/2007 5:50 PM
Cartman
http://www.nebraskatire.com/truck/overstocks.htm
this looks interesting.
DS
#151752 03/29/2007 7:04 PM
Hello, You might have already tried this but your local farm Co-op (Cenex or eqivelant) should be able to get you good 7.50,8.00,8.50 x 20 etc without a problem. Its pretty common here in Mn to have a grain truck on the road and working thats 45 plus years old. Good Luck anyway!
240,000 worker bees!
1960 Two ton Chevy
#151753 03/31/2007 12:19 AM
I bought my 7:50 20's from Goodyear. For some reason down south they call them "Wingfoot" tires. Why I don't know. But, be prepared for a mounting problem with the split rims. But, I recommend that you stay with the 750's rather than the bulkier 8:20s unless you plan to haul heavy loads. They look much classier and more classic. G. Berry
#151754 03/31/2007 1:00 AM
1 Offline
I bought Chinese tires traded under the name "double happiness". The local tire supplier I use delivered them with tube and flap for $106.00 each. They look classy and are priced right, maybe there not good for that perfect original restoration. My thought is try it. I was going to buff the double happiness off, but I think it will be interesting car show talk. I mounted them myself not that bad to do, but if you don't know how I wouldn't try it you can do some real damage. My two cents and 15 min. of typing :hammering:
restoring a 1946 coe wrecker.
#151755 03/31/2007 2:58 AM
Former Workshop Owner
I would have to buff that off also. It's bad enough that many "Originally American" name brand items are made in countries by slave labor, but I don't envision enough happiness being spread around for the laborers to enjoy, that would warrant bragging about it.
No offense intended, just expressing my honest opinion.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#151756 03/31/2007 3:13 AM
Definitely DO NOT mount these tires yourself without consulting with an experienced truck tire man. Read that sentence again! They can be mounted by the average person BUT, the inflation process could KILL you! Read the last three words again! A bit extreme I know, but please learn the proper and safe method of tire replacement for 'split type truck wheels', if your going to do it for your self.
Insert clever statement here:
#151757 03/31/2007 1:18 PM
consult your shop manuel to be sure if you are dealing with split wheel or multi piece lock ring wheels
