5 members (WICruiser, Gdads51, 55shaker, Ponchogl, DadsFirstPickup), 121 guests, and 1 robot.
Topics128,054
Posts1,055,782
#1517112 09/13/2023 5:08 AM
Looking to get 1948 Chevy truck, it comes with an extra 52 5 window cab, would it be interchangeable? I am assuming the hood, fenders and doors would not match up from the 48 would they?
The cab should easily swap over. The '48 may have a single rear mount, but there's no reason that the mounts for the '52 couldn't be installed if that's the case. Might need drilling the frame rails for the rear cab shackles. The doors are not easily interchangeable between '48 and '52 cabs. The latch mechanism is different. But hood and fenders are interchangeable.
Remember that the vehicle id plate is on the driver's door jamb and it's generally illegal to remove it or swap it between vehicles. Is the '48 registered/titled? Swapping the cabs could possibly lead to problems with your DOT or if you ever sell the truck.
Figure all that out in advance.
1950 Chevrolet 3100 (Ol' Roy)
Crusing in the Passing Lane
If drilling the frame for any reason, drill only in the web, not the flanges. The web is the vertical part between the horizontal flanges.
Ed Pruss
Ed Pruss
Thanks Ed, I should have mentioned that. The shackle bracket holes on later frames using the 4-point cab mounts are in the web. If dogdaddy needs location dimensions for those holes, I can provide them, as my cab is not yet mounted on the frame.
