3 members (Peggy M, Otto Skorzeny, Ponchogl), 87 guests, and 1 robot.
Topics128,052
Posts1,055,729
#1516886 09/11/2023 8:13 PM
I don’t remember the last time I removed a flywheel. I got the last bolt out this morning so looking for some words of wisdom.
I’m going to put something under it so it doesn’t chop off anything important.
Doug
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
Doug
Good idea. Like fingers. eek
T-Doug #1516902 09/11/2023 10:18 PM
Stick a piece of round stock through the hole in the bell housing and into the pilot bushing. If you happen to fumble the flywheel, it will only be able to drop a couple of inches.
T-Doug #1516913 09/12/2023 12:33 AM
Good idea Jerry. It worked like a charm. Used the rubber mallet and it came off no problem.
It’s resting on the wood dowel with the floor jack holding it in place. It was to hot out to continue so I’ll wait until after supper when it cools off and get it on the ground.
If I do it will go to the machine shop tomorrow.
Doug
1954 Chevy 3100
Montgomery, AL
In Project Journals
Flywheel is in the truck heading to the machine shop.
1954 Chevy 3100
Montgomery, AL
In Project Journals
