2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
#1516873 09/11/2023 6:09 PM
1 Offline
What is everyone seeing for top speeds on the stock driveline (1948 1/2 ton, 216, 3-speed, 4.11 rear-end). She seems really happy at about 45mph, but anything over seems like asking a lot. Its hard to tell without a tachometer, and it seems like she can do it, but it sure seems like a lot. Wanted to get everyone's feedback. Thanks!
My 51 is all back original, same engine and driveline as yours. And yep, 45-50 is where it likes it, but I've run it 55-60 on the interstate with no problems. That 60mph does make it sound as though it's wound up a little too much though.
Mike
1951 3100 5 window
Before I put a 235 in my 1950 3100 ( original driveline, 3-speed, 4:11 rear gears) the top speed was about 55 mph. That was per GPS on my cellphone. Yes it was up in rpm's but stovebolt engines are made for that!
I get up to 62 Ish mph now with 235 in it, same drive line!
1950 Chevy 3100
H Online: Content
Take a drive with the fan removed- - - -I think you'll be able to figure out where most of the noise is coming from. It doesn't make good nonsense to be worried about running an engine up to the RPM range where the factory rated its horsepower as long as the bottom end bearings are in good shape..
Mine is original. Happy at 50-55. It will do 65+ but does sound like it is really wound out.
Dave from Northern Kentucky
My 54 3100
55-60 on the interstate on a weekly basis. 65 is tops but I don't cruise at that speed.
This was made possible by installing the correct diameter wheels (16") and correct size tires. A new clutch helped a lot, too.
unrestored 216 and 3 spd trans, 4.11 rear end
1950 Chevrolet 3100 (Ol' Roy)
1 Offline
Awesome! Glad to hear everyone is in the same boat. I do have original-size bias-ply tires (6.50x16). Once I get some exhaust leaks fixed it might not sound so chaotic.
H Online: Content
Back when I was in college, my daily driver was a 1958 Chevy DelRay coupe with a 235/3 speed drivetrain and a 3.70 rear end. It also had 14" wheels and low profile tires. I drove it home 150 miles just about every weekend at 65-70 MPH, and it would do 80 in a short sprint when needed for passing. Stovebolt engines are a lot tougher than folks think!
Mine liked 45mph, and on the highway it seemed to favor 58mph. Speedometer has been out of service a while, but here's a tach pic. It would cruise all day. Past tense because it has a T-5 now, and I wouldn't change it back.
https://media.fotki.com/2v2E1CzrSxDubp.jpg
Buy a set of 215/85R16 tires on it. They are 30.5" compared to your 28" tires. That will give you a noticeable increase in speed with less RPM.
Have your rims sandblasted and epoxy primed, and use epoxy on the rivets which hold the rims together. You can then run those tires tubeless. I recommend the valve stems which are held on by a nut.
I have a 1954 235 with a 2.73 Nova rearend and a T5 5 speed It will cruise all day long at 65-70 and around 2100 rpm. I am getting ready for KC this week and I always have my fingers crossed. I have never had it beyond the posted speed limit but would like to try on my home turf btw also disc brakes on the front.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
