1 members (DadsFirstPickup), 85 guests, and 1 robot.
Topics128,118
Posts1,056,305
Members48,439
Sharing an experience:
Last fall I had a wire catch fire under the dash after turning on the ignition switch (burned the old fabric housing off was the only damage). The culprit was the wiper control arm that had fallen off and landed / wedged in the perfect spot to cause a short; it was laying on top of an original wire (the one burning) and the rod was connecting the positive post of the ignition switch and was grounding to the metal dash. In the photo you can see etching on the rod. I have since wrapped the rod in electrical tape in case it falls off again.
Roger
morerog,
That is a helpful safety tip.
Thanks for sharing.
Dan
~ Dan
1951 Chevy 3 window 3100
Yes,
Something to put on TODO list as an item to check out. Thanks for the heads up.
Craig
Another reason why I don't use that linkage. I use a piece of TIG welding wire and make my own wrap around ends so that it will never come off without a pair of pliers. Counting on a piece of rubber for the end of a linkage to stab through to keep it of for any length of time was just a dumb idea.
maybe wiggle some heat shrink around it.. the tape might fall off after another 40-50 years or so.
Another quality post.
Real Trucks Rattle
I put some heat shrink over the ends of mine, easiest to do that with the gauge cluster out but it worked like a charm. Mine kept falling off as well before that, hasn't happened since
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
thanks for the heat shrink suggestion!
