2 members (Steelonsteel, WingWright), 87 guests, and 2 robots.
Topics128,050
Posts1,055,760
#15163 06/03/2003 3:35 AM
Pal
Offline
Ok, call me a dummy, but for the life of me I can't get the window crank off my drivers door for replacement. I about a heartbeat from taking my dremmel to it. Any suggestions?
Pal
35 + years of rollin' steel!
#15164 06/03/2003 3:45 AM
your window crank is held on with a horseshoe clip...don't pry it off or you will screw up the whole thing. spend the money on the tool. may i also make a suggestion as to even a haynes shop manual for info on how to do these smaller operations?
1961 Chev 3/4
1977 Chev Nova
#15165 06/03/2003 3:52 AM
Pal
Offline
I'll go get the right tool. BTW: I couldn't find it in my Chiltons.
#15166 06/03/2003 3:58 AM
i've only flicked through some Chilton's a few times but i think i remember they were a little short on the small stuff like that ie interior things
1961 Chev 3/4
1977 Chev Nova
#15167 06/03/2003 4:06 AM
Pal
Offline
Out of curiosity, how are the original shop manuals? I found a source on book or CD rom, but don't want to spend $40 - 60 on a dog.
#15168 06/03/2003 4:49 AM
Depends on the year. None of my trucks built before '67 use the horseshoe clip. I use a hooked pick to pull the horseshoe clips. On the old set screw type, sometimes old timers would put two screws in, one on top the other, to keep them from working out. I've run into that, and some that were just plain tough to get off.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
#15169 06/03/2003 5:19 AM
shortly after getting my 61, i figured that i should spend the money as i am redoing front end, wiring, etc and it has proved invaluable as far as torque values, wiring code, and even panel removal. cost lots, but gets used lots.
1961 Chev 3/4
1977 Chev Nova
#15170 06/03/2003 7:45 AM
If it's the set screw type of handle, removing the screw and spraying some penetrating oil (PB Blaster, Kroil, etc.) down the hole and onto the splined shaft might help. Worth a try.
1954 GMC De Luxe COE
#15171 06/03/2003 5:54 PM
The set screw type have a decoration plug that looks like a screw that you have to remove and then the real set screw is way down in there. It fooled me the first time.
Paint & Body Shop moderator
#15172 06/03/2003 8:44 PM
My door handle fell on the floor one day, when I made a turn. Later, I went to put it back and couldn't find the retainer clip (horseshoe clip) and started freaking out -- WHER can you buy THOSE???
Well ... after calming down and making a further inspection, I discovered that my handles aren't original handles! They have an allen screw at the base! Wa-laa! A little tightening of the allen screw was all that was needed.
MAYBE yours are the same?
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#15173 06/03/2003 9:21 PM
horvath,,,, those ARE ORIGINAL handles grin
