2 members (Don88, Nick in Manitou), 111 guests, and 2 robots.
Topics128,162
Posts1,056,936
Members48,458
Looking for the GM part number for my 1950 3100 Wheel Studs? (Aka lugs). I can not find it in any of my books. One of my rear has 4 out of the 6. (2 broken off) Thank you in advance!
Todd
1950 Chevy 3100
Don't know the GM Part # but the Filling Station has them. Link
Or you could drive out one of the broken ones and take it down to your FLAPS with the length of the intact lug bolt and a lug nut to check the thread diameter and pitch. They should be able to fix you up.
Most NAPA stores carry an assortment of lug bolts/nuts and can get any they don’t have in stock within a day or so.
Thank you both.
I will have to remove one and compare.
The filling station does show the GM numbers as a reference. Not sure why there is two different ones.
1950 Chevy 3100
Note that on that Filling Station link, they call out different knurl diameters and lengths as well as different overall lengths. That's why it's good to eyeball them side by side with an original, although the FS does call out specific applications for each one.
H Online: Content
The thread will be 7/16-20, but there are several different lengths and knurl sizes available. It would be best to drive out a good one and compare it with a local parts store's bench stock. I use a ball joint press and a 3/4" drive impact wrench to install wheel studs. Don't try to pull them in with a lug nut and a stack of washers- - - -you'll stretch the threaded part of the stud.
Kevin & Jerry ,
Thank you. I appreciate the input.
Have a Safe day
Todd
1950 Chevy 3100
