0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
I took my generator apart today in hopes of cleaning and painting the casing. Unfortunately when I opened it up it appears like something has melted inside. It worked when I took the truck apart.
I have rebuilt about everything else in the truck and am hoping to start putting it back together when it comes back from the paint shop next week. While I don't want to go down another rabbit hole of hunting down a rebuild kit I also don't want to cut corners.
Any insight or thoughts would be appreciated.
1952 Chevy 3100
In the DITY Gallery
H Online: Content
That's a pretty neat trick- - - -making a "generator" from a starter! If it was working OK before you disassembled it, don't worry about the deterioration of the insulation. If it makes you feel better, use an air gun to blow away any loose stuff and mix up some 2 part epoxy cement to recoat that area of the armature. Don't increase the diameter enough that it will drag on the housing. You should change the brushes and bushings while you've got it apart.
Thanks Jerry. I am well trained in calling things the wrong thing…trying to do too many things at once!!
Should I try to knock the melted stuff off or just blow it out?
1952 Chevy 3100
In the DITY Gallery
H Online: Content
Don't disturb anything that's still stuck tight- - - -just blow the loose stuff away and use something like a stiff bristle artist's brush to apply a thick coat of epoxy to the area, especially the bare spots. You don't want to create a short between the windings and the armature laminations if one doesn't exist now.
Add a small amount of acetone to JB Weld to thin it enough to paint it on. The acetone will evaporate out and the JB Weld will cure as normal.
1950 Chevrolet 3100 (Ol' Roy)
H Online: Content
Doesn't JB Weld have metallic powder in it? I don't think that would be a good idea around high current DC armature windings. Plain old 2-part epoxy is an insulator. I've seen JB Weld rust when used to patch engine block cracks.
I thought it was plain epoxy but I'm probably wrong. They have several versions, though one is plastic, etc.
I found brushes, bushings and springs for my GMC starter at O'Reilly's. A little clean up on the armature (DON'T use Emory cloth, the remains conduct electricity) and it has run 20,000+ miles with no problems.
