2 members (WICruiser, Gray_Ghost), 106 guests, and 4 robots.
Topics128,164
Posts1,056,967
Members48,458
#151639 03/20/2007 1:02 AM
Junior Member
Junior Member
I set out to change the lube in the rear end of my 1949 4100, single speed rear end. I found the fill plug, but was unable to find a way to drain it. What am I missing? Do I have to remove the rear housing to get it drained. I'm worried about finding a replacement gasket, if I do.
Any ideas appreciated.
Jaskey,
I 'think' you can pull the fill plug, then remove one or two of the bottom bolts from the cover and, voila, out comes the lube. Removing the fill plug acts as a 'mega-vent'. Just put a little silicone on the bolts when you stick them back in.
Stuart
I just sucked my fluid out the fill hole. Worked fine. Sure I missed a tiny bit of gunk at the bottom, but got 98 percent of it.
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
#151642 03/20/2007 10:05 AM
I concur with removing one or two of the bottom cover bolts as that is what worked for me. The filler plug will work as an air inlet.
1951 1 Ton Completed
Junior Member
Junior Member
I think I will try removing a couple bottom bolts, with the filler plug out.
Thanks to all for the suggestions.
I pulled off the whole cover just to look at the condition of every thing. Gives me a chance to clean out the gunk in the bottom and blast and paint the cover before using a good RTV and sealing it back up. I had a previous post on the crud in the rearend. No way was that thick stuff coming out by just removing a couple of bolts.
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
Junior Member
Junior Member
So, you just ran a bead of RTV (silicon ?) around the cover when you put it back on. No gasket?
I like the idea of seeing the condition of everything inside.
Thanks!
Yeah, just run a bead of black RTV around the cover, smooth it out around the bolt holes just enough to get about an 1/8" thickness put the cover on and start your bolts. Tighten evenly and wipe off any excess, or wait till it dries and cut any excess with a razor blade. I've done it ton's of times. No leaks. grin
#151647 03/20/2007 10:10 PM
Junior Member
Junior Member
I'm going to give it a try.
Thanks!
#151648 03/20/2007 11:47 PM
Jaskey,
Another old trick to make yer own gasket,if ya dont gottsa new one is to use a cover from a
Pizza Box eek
Not the serrated kind like Dominoes.
The flat one piece sheet that most reg mom an pop stores have! wink
Regards............
RTV Will work fine, that's what was used even from the factory on many of the later trucks.
1970 C50 dump! saving orphans from the CRUSHER
