1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1516117 09/06/2023 1:37 PM
1946 2 ton lug hole wheel shape is not round.
After the thrust plate is removed from the wheel you see that all the lug holes are
not round.
Rather they are a long oval. About an inch long.
I have a photo on my phone that I can text the photo for a correct evaluation.
I would greatly appreciate if someone that received my texted photo would post
the photo on this thread.
Thank you,
Jeffrey
Here is his image.
Lug image
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
3B Offline
Hy 32vld, the wheels you are talking about are now scrap, it sounds like they must have been run loose for some time.
Not good, check the other wheels...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Will do.
Maybe it is time to upgrade and replace all the old split rim wheels with a one piece wheels.
Jeffrey
Are the wheels tight on the pilot diameter on the hubs? That's what centers them on the hubs. If they are and you have the top plates remove any burrs from the wheels and I would think they would run fine as long as there tight.
I wouldn't use those wheels. If the lugs are even the slightest bit loose, the oval holes will have a "run" at the lugs and hit them harder than if the holes were round. Impact really multiplies the force, and the lugs might shear off, resulting in a really bad day.
No way would I run that wheel. With that big of a slot the wheel can rotate on the hub putting a lot of force on the studs when hard braking. Your just asking for it to sheer the studs off and leave you with one less wheel going down the road...not good! Turn that wheel into a backyard fire pit!
Mike B smile
Kevin beat me to it...LOL
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
As far as that go's, if your that worried about the wheel coming off. The studs should be changed when you replace the wheel because I'm sure they have been stressed from all the back and forth hammering besides being 77 years old!
Ooh, I like the back yard firepit idea, because I've got a bunch of FR-5s that can now find a more safe function in life.
