7 members (mick53, Tiny, Southerntruck, HandyAndy, TUTS 59, 2 invisible), 82 guests, and 2 robots.
Topics128,093
Posts1,056,046
Members48,433
#1515740 09/03/2023 8:55 PM
the metal connetion between the fuel pump and the pressure side fuel line has a pesky slow drip. I cannot tighten the fitting any further. Any suggestions? (other than replacing the fuel line).
1951 chevy 216.
Thank you
7
7 Offline
what type of fitting is the joint, flare, inverted flare, compression, pipe thread?
If we are talking the stock inverted flare fittings….
Try loosening and tightening. Repeat that process a few times and you might get an extra quarter turn without excessive force.
If that doesn’t work, some aviation sealer or Super 300 on the male threads. Very sparingly.
1951 3100
Take it loose, add some grease on the back side of the flare and a little on the threads, then retighten and see if that helps. If not, replace the line and start again.
Thanks for the thoughts thus far. connection is flared fitting; flare on the line inserted into the fuel pump joint.
AD Addict & Tinkerer
More than likely you’ll have to replace the fitting and re-flare the line. The flare gets work hardened after taking it off and on over the years and no longer seals. You should have enough line to cut off just the end to remake a new flare. If not, you can replace the line with a pre made-up one from the vendors or just make up a new one. I used CuNi (copper/nickel) with a cheap HF bender and it came out great.
Phil
Project Journals
Stovebolt Gallery Forum
Carburetion specialist
Fuel is designed to BURN!
A new fuel line (if you are unable to bend one) AND new fittings at both the carburetor and fuel pump are MUCH cheaper than an engine fire!
The fuel line in Phil's pictures is quite easy to bend.
Jon
The Carburetor Shop
