1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
#1515510 09/01/2023 9:46 PM
Any advice installing the rope seal on a ‘54 235?
Csteve #1515521 09/01/2023 11:59 PM
Consider using a neopreme seal. I did one ten years ago and have had no leakage.
A 54 engine will not work with a neoprene seal. Here's the permanent fix, but it requires machining the back of the block and rear main bearing cap:
https://www.bdiexpress.com/us/en/Ca...8647-3-875X4-751X0-375-CRWA1-R/p/1244244
If you use a seal from BEST GASKET , they have instructions with them. Best uses material that holds it shape, very much like the old seals did before removing all the harmful material from them. New seals are just rope with some graphite mixed in.
