7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible), 88 guests, and 1 robot.
Topics128,074
Posts1,055,910
Members48,429
#1515039 08/29/2023 4:33 PM
Stupid question…
I don’t want 4wd in my 1949 GMC 1 ton.
So If I buy a Dana 70 SRW rear end (or a Dana 80 Dually) will I have to buy a matching front end? Aside from the matching bolt pattern, are there non 4wd front end options that’ll match up?
EffDubya #1515043 08/29/2023 5:17 PM
Keep the original front axle and rebuild it to "as new" condition- - - -king pins, tie rod ends, drag link, etc. Ditto for the steering gear. With a little creative tinkering it can be converted to disc brakes. There's nothing wrong with an OEM front axle- - - - -millions of them hauled thousands of tons of cargo for several decades- - - -there's no reason it can't handle transporting an iced-down Yeti cooler to a car show these days!
EffDubya #1515069 08/29/2023 7:13 PM
What does "match up" mean to you? The stock front axle is already the right width for the fenders, and if the lug pattern mismatch doesn't matter to you then there really isn't any reason to change it.
Like Jerry said, the overall design of the front axle hasn't changed in close to 100 years. I would put disk brakes on the front for wet weather and hard use performance but that isn't even strictly necessary.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
EffDubya #1515073 08/29/2023 7:21 PM
A 1 ton front axle should have the same 8 lug bolt pattern as a Dana full floater- - - -either a dual wheel type 70 (preferred) or an "overkill" 80. Other than disc brakes, I can't think of a good reason to go to a later model front end. Doesn't Domek sell a disc conversion for the 3/4 and 1 ton front axles?
