0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15147 02/05/2002 5:26 AM | Joined: Feb 2001 Posts: 41 Member | | Member Joined: Feb 2001 Posts: 41 | I'm dealing with one of the threaded shackle pins on the back end of my rear leaf springs (on a '57). The other three pins screwed out smoothe as silk. A stiff breeze could have unscrewed them. The fourth, however (left side that screws into the hangar itself) will not budge.
On the third application of heat I finally got it to break free slightly, but it will only move about 5 degrees--no further. I'm wondering if anyone else has had this much trouble with a threaded shackle pin, and if there are any tricks to getting them out? Thanks, Ed | | |
#15148 02/05/2002 1:11 PM | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | I'm doing this now too...had a couple tough ones. With the stuck pins,I was able too get them out with liberal doses of penentrating oil,a pair of vise grips(w/nice sharp teeth!)and a propane torch to heat the hanger ( and spring when it was thier turn)Just DON"T use the torch and oil at the same time! If you are going to be removing the bushings too,BOYOCONNOR has a good post in the TECH TIPS page for that (there's also a post by me close to yours on the same page) | | |
#15149 02/05/2002 9:09 PM | Joined: Feb 2001 Posts: 41 Member | | Member Joined: Feb 2001 Posts: 41 | Thanks Russ, Unfortunately I was using gobs of penetrating oil and was heating the hangar to cherry red with an acetylene torch and the pin still wouldn't budge. I ended up just hammering out the entire bushing with the pin in it. I sure hope I can find another one of those threaded bushings...
Ed | | |
#15150 02/05/2002 10:55 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | slatye, Those threaded bushings come with the spring shackle kits...
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#15151 02/06/2002 6:56 PM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | Now you know why they have grease fittings on those shackle pins! -Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
