7 members (jmoore, kades51, Otto Skorzeny, TexasA&M48Truck, Frank50, Jon G, 1 invisible), 74 guests, and 1 robot.
Topics128,132
Posts1,056,379
Members48,441
#1514740 08/27/2023 6:29 PM
47-53 series GMC 250 (1 Ton, 4 speed) Transmission shifter and emergency brake seals that fit below the floor pan and prevents "fumes and heat" dance from entering the cab. See attached pics, thanks. If they don't repop these, what did you do?
15 minutes with a box cutter or a razor sharp filet knife and a piece of 3 inch thick foam rubber- - - - -problem solved!
Perhaps something like this material???
Closed cell 3' thick x 12"w x 1' length
Dan
~ Dan
1951 Chevy 3 window 3100
AD Addict & Tinkerer
Foam slices like butter using an electric knife. If you don't have one, you can usually find them in a thrift store or yard sale for a few dollars.
Phil
Project Journals
Stovebolt Gallery Forum
Any of the typical vendors had these, are they no longer available?
https://oldchevytrucks.com/catalogsearch/result/?q=fl137 for the floor shift foam seal, and for the emergency brake floor seal # 30-1884 from LMC.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
With everyone help, I found all of this at Jim Carters. Thanks again for the advise and direction! The parking brake designation instead of emergency brake designation made all the difference!
JIM CARTER
1948-1955 Park Brake Floor Boot Pickup Panels Chevrolet and GMC Pickup Truck
SKU FL119
$5.55
1948-Early 1955 Park Brake Lever Floor Boot Metal Cover Chevrolet and GMC Pickup Truck
SKU FL120
Special Price$4.74 Regular Price$7.30
1934-1965 Floor Shift Foam Collar Four Speed Floor Shifter and Three Speed Floor Shifter Chevrolet and GMC Pickup Truc
SKU FL137
$9.40
1934-1959 Park Brake Foam Collar Chevrolet and GMC Pickup Truck
SKU FL138
$8.35
Fits between hand brake lever base and under floor to stop air leaks. Also fits larger trucks, 1948 and newer having vertical hand pull lever. MADE IN USA
Way to go!
Thanks for coming back and providing such a great close out, including all the part references! thumbs_up
Dan
~ Dan
1 Offline
The park brake foam doesn't completely seal on mine so the boot is essential. I'm even considering a fancy leather boot for a better seal. Any heat you can keep out of the cab in summer is money well spent, I think. However in winter the air leaks do augment the heater once things warm up.
1951 3800 1-ton
In the DITY Gallery
