4 members (Cosmo, wilbur53, Bill Marlow, 3B), 167 guests, and 0 robots.
Topics128,049
Posts1,055,549
Members48,425
#1514661 08/27/2023 12:06 AM
I know I’ve seen several threads about sending units here but wanted to ask again.
How do I test a new sending unit. Can I just attached the positive to the center post and then clip on the base with the ground. Move the float and see if the ohms change.
Doug
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
Exactly
Moderator, Electrical Bay
Yes...at empty it should register 0 oms and at full it register 30 ohms.
~ Jon
Question. Is that reading going to transfer properly to the actual gas gauge in the truck?
I am in the habit of testing the sending unit in the truck where I can watch the
needle move E to F.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
The new one I put in wasn't tested just took it on faith that it worked..
Tested this one and it reads just like it should.. 0 to 30 ohm from empty to full.. now I'll swap it out with the old (new) one and see if the gauge works..
Doug
1954 Chevy 3100
Montgomery, AL
In Project Journals
needle move E to F.
Only if the float reaches all the way to the bottom of the tank and all the way to the top of the tank. Anywhere in between and you'll get approximations of fuel level.
Adjust your float arm if necessary to accomplish this.
1950 Chevrolet 3100 (Ol' Roy)
High F is OK with me, the E has to be right.
With all 3 of my tanks under frame, accessing the sending unit
after installation is hard to do sometimes. Thanks Otto!
~ BD.
