6 members (TUTS 59, HandyAndy, dt235sd, Bill Hanlon, 2-Ton, Brian Moore), 109 guests, and 2 robots.
Topics128,060
Posts1,055,836
Members48,427
#1514707 08/27/2023 2:33 PM
Can anyone id the gear ratio . Pumpkin housing marker 8699535 and 350 or 360 ? 1949 3600 supposedly had farm gears from factory . Also its a 4 speed. Thanks!!!!!!!!!!!
49.3600 #1514711 08/27/2023 3:13 PM
49.3600,
According to a Chevrolet 1929-57 Master Parts and Accessories Catalog, your original pumpkin housing "casting" # should read 3699535. Is it possible you misread the number on your pumpkin???
A check of the 1949 Chevrolet Truck data indicates that the standard rear axle ratio for your 3600 would have been 4.57 - 1, with an optional (RPO 208) ratio of 5.14 - 1 available.
You can identify the gear ratio by using this Calculation Tech Tip, or just remove the rear cover and check the stamped ratio info on the side of the ring gear.
Hope this info is helpful?
Dan
~ Dan
1951 Chevy 3 window 3100
49.3600 #1514717 08/27/2023 3:34 PM
Thanks Dan , any thoughts on putting in a high threes of minimum a 4.11 . Would like to drive it haha, it is a museum restoration
49.3600 #1514728 08/27/2023 4:38 PM
49.3600,
You are in luck my friend!!! thumbs_up
Check out this on-topic Rear Axle Upgrade Tech Tip which was originally written for 1 Tons, but applies to the 3600 3/4 Tons too! yahoo
Dan
PS - There are tons of existing threads discussing this subject that you can find by using the Search the Site tool too! wink
~ Dan
49.3600 #1514732 08/27/2023 5:03 PM
Finding one of those 4.10 gearsets is about like searching for a chicken with lips! A lot of them got installed (and worn out) in dirt track race cars in the late 1970's. They were just right to run against a Muncie 4 speed in 2nd. gear on 1/4 mile tracks. They made the engines run 3K RPM in the turns, and 7K at the end of the straights! We scavenged up every one we could find in all the salvage yards back then.
