| | | Forums66 Topics128,268 Posts1,058,375 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 66 | Would the PTO, the ram, and the dump bed switch from a 3800 to a 4400? Thank you, Scott | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the dump fits and the 3800 has a pto point ..... you got a tape measure?
Bill | | | | | Joined: Dec 2006 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 66 | Let me rephrase: With regard to a 3800 vs a 4400, are the PTOs and transmissions the same size? The rams? The rails? I was told about a 3800 a few hours away from me that has this dump, if it was in my yard, I just might be able to measure it, but I was trying to get some info and save myself a trip. Sorry if I appear stupid to you. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not stupid, maybe just not thinking far enough! for starters, if the trucks are the same years, they'll have the same transmissions, there was only one 4 speed back then - the pto's are mostly aftermarket, whatever suits the pump and rams, if the pto fits on a 54 4400 trans, it'll fit on a 3800 trans [or it could have an engine mounted electric pump] - the 1T and 1.5T still have the same distance between the rails, so what counts is if the trucks are a similar wheel base, and the length of the deck, but that can be modified
the point is, either model could have had an aftermarket dump put on it, and the dump would be whatever the installer wanted, so all you can do is check the dimensions and see if it'll fit on yours, and see how heavy it appears, and if you think the 3800 can handle it
I put a dump setup on my 1.5T 46 that came off the ground, probably previously on a late 50's early 60's gravel truck - ya do what's needed, if you're lucky it won't take much fiddling
Bill | | | | | Joined: Jul 2005 Posts: 71 Member | | Member Joined: Jul 2005 Posts: 71 | Perfectly reasonable query, Scott  | | | | | Joined: Feb 2000 Posts: 120 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 120 | Hey Scott, I,ve got a 54 4400 with a flatbed/dump if you need measurements or pics. Also, looking for a 3800 if you deside not to buy this truck. I would be interested in the Cab & Chassis if you are buying just the dump body. Thanks, Jim D. 1954 44001954 3800Jim D. '41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck '54 Chevy 3800 Dump........New Truck! '54 Chevy 4400 flatbed/dump, Gone to my brother-in-law '13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles '01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
| | | | | Joined: Dec 2006 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 66 | Thank you very much. I sent a message to you concerning the truck. Scott | | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | I would confirm measurement from back of cab to center of rear axle. You want the dump box to fit the wheelbase and look right. However, as mentioned before rear axle can be moved to accomodate desired wheelbase,although modifying enclosed driveline may be spendy. This is common practice when installing aftermarket bodies. A local shop that services-install truck bodies could be helpful....Jeff
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
| | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | I should also add, withwise these dumpbeds then as now should be a universal fit. The same bed should fit all truck brands.
