6 members (1955 1 Series, 50Chevy3100, RdsLessTaken, DadsFirstPickup, tclederman, 1 invisible), 172 guests, and 3 robots.
Topics128,107
Posts1,056,225
Members48,436
#1514044 08/22/2023 7:15 PM
This is a 1 Ton truck (pretty sure). I know there were options for rear ends & I know it’s not a torque tube, but the question is, can an 8 bolt stock rear handle an 400hP LS swap? I have an ‘87 2wd s-10 rear ready to replace it (more wheel/tire options on the 5 bolt) but is that even doable? Reason I’m asking is most people are modding 1/2tons and 3/4s, not as many 1 ton (non duallys) out there so it’s a little more of a challenge.
Consider that the stock rear end ratio on 1 tons was 5.14:1 while you are deciding to change it out or not.
I don’t think 5.14 will give me the highway speed I’m looking for. But I see there is a 4.10 gear swap or something out there for the Eaton HO that might give me a little more speed for long haul travel. I guess my next question will be about modern rear end swap options for this 1 ton…
EffDubya,
You want to take a look at this very excellent "on-topic" Tech Tip from the main Tech Tip page.
Right on the "upgrade" subject you are asking about! thumbs_up
Dan
~ Dan
1951 Chevy 3 window 3100
Crusing in the Passing Lane
FF 14 bolt, D-70 and 80 are optional rear axles that have a good selection of modern ratios. Obviously bolt patterns and width must match.
Ed
I gave up trying to find a 4.10 ratio Eaton HO and installed a 14-bolt rear from a 1986 C3500. I needed to change the srping perches and shock brackets etc. following the excellent write up regarding this conversion. I have a 1950 3600 so your setup may be different but the pictures look really familiar.
1949/50 3600 Project
Follow in Project Journals
What are you doing for a bed on it? The weight limit on the S10 axle is much lower and you could consume the greatest majority of your carrying capacity with just that.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I have a Nova rear end in my 54. But the gear ratio is 2.73 I am told. But it is OK for what I use it for, transportation like a car. It does have a T5 transmission and the original 235 engine.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
