This is a 1 Ton truck (pretty sure). I know there were options for rear ends & I know it’s not a torque tube, but the question is, can an 8 bolt stock rear handle an 400hP LS swap? I have an ‘87 2wd s-10 rear ready to replace it (more wheel/tire options on the 5 bolt) but is that even doable? Reason I’m asking is most people are modding 1/2tons and 3/4s, not as many 1 ton (non duallys) out there so it’s a little more of a challenge.
Consider that the stock rear end ratio on 1 tons was 5.14:1 while you are deciding to change it out or not.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
I don’t think 5.14 will give me the highway speed I’m looking for. But I see there is a 4.10 gear swap or something out there for the Eaton HO that might give me a little more speed for long haul travel. I guess my next question will be about modern rear end swap options for this 1 ton…
Right on the "upgrade" subject you are asking about!
Dan
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
I gave up trying to find a 4.10 ratio Eaton HO and installed a 14-bolt rear from a 1986 C3500. I needed to change the srping perches and shock brackets etc. following the excellent write up regarding this conversion. I have a 1950 3600 so your setup may be different but the pictures look really familiar.
What are you doing for a bed on it? The weight limit on the S10 axle is much lower and you could consume the greatest majority of your carrying capacity with just that.
I have a Nova rear end in my 54. But the gear ratio is 2.73 I am told. But it is OK for what I use it for, transportation like a car. It does have a T5 transmission and the original 235 engine.
Ron, The Computer Greek I love therefore I am. 1954 3100 Chevy truck In the Gallery 2017 Buick Encore See more pix 1960 MGA Roadster Sold 7/18/2017
