0 members (), 177 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
#1513852 08/21/2023 5:53 PM
has anyone repaired these hinges? it appears that the pin has rusted and the arm is wobbly. thought i could drive the pin out and replace it with a new one or alittle bigger if needed. but the pin is not moving. do i need a bigger hammer or is there a trick? thanks. Heat?
There was a really good writeup on rebuilding those in the last year or two, but I can't find it at the moment.
Maybe someone with better search-fu will come up with it while I keep looking.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Thanks did a search and found a few. big hammer and heat seem to be the fix.
I tried at one time. With the hinges I had ,any repair would
have been difficult and probably damaging. The hinges were just worn out by that point anyway.
Worn out pins was the least of worry. New ones were a better option.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
I had a similar experience. I started rebuilding mine on the 57 1/2 ton. I couldnt find replacement arms for the upper hinge keepers. I was able to do the pin repair though. I wound up buying repops and had to enlarge the slotted holes and rework the angled portion were it fit in the door pockets. I’d use original hinges if I could fix the keeper mechanism since they fit in the doors much better.
Larry
Classic parts hinge pin worked great for me. It's been 10 years, but I think I pushed the pin out with a BFH after letting it soak in PB Blaster for a while. I didn't have a press. Pins are oversize. You drill the hinge to fit. $4 per pin.
Thought I would update my progress. The bigger hammer is the answer. was able to drive the pin out and found that the bushings were shot and the pin. ordered a repair kit and it came with bushings and pins. needed to open the part that holds the door so the bushings would fit a 27/64 drill did that. pressed the bushings ,put it together and pressed in the pin. good as new.
