4 members (qside, dunfire, GRNHydra, Rnl364), 93 guests, and 2 robots.
Topics128,064
Posts1,055,859
Members48,428
#1513535 08/18/2023 11:45 PM
I’ve got a leaking, smashed fuel tank that I’m looking to replace. The ones I see online don’t look quite the same. Any suggestions on where to find a replacement? It mounts on the passenger side frame rail, on the outside of the frame. The filler neck points up.
1947 chevy 1.5 ton Loadmaster
Someday2023 #1513541 08/19/2023 1:31 AM
What’s it going on ?
Someday2023 #1513554 08/19/2023 2:41 AM
hcb3200,
Soemday2023's previous posts mentioned a 1947 1.5 Ton.
Someday2023,
Just a suggestion, but adding a "signature line" to your profile will allow you to add info about what truck you have, including any special details you want to include. Doing that will automatically include that in each of your posts (like my signature line below), making it easier for folks to offer direct suggestions or replies to your questions.
Dan
~ Dan
1951 Chevy 3 window 3100
Gdads51 #1513558 08/19/2023 2:48 AM
Originally Posted by Gdads51
hcb3200,
Someday2023,
Dan
Thank you Dan. I’ll work on that for sure. Any suggestions to make things easier I’m on board with.
hcb3200 #1513559 08/19/2023 2:49 AM
1947 chevy 1.5 ton flatbed truck.
Someday2023 #1513565 08/19/2023 3:54 AM
Looks just like the one on my '47. Can't help you out on a replacement, though. Sorry!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Someday2023 #1513577 08/19/2023 11:12 AM
7
7 Offline
Hi Someday2023, go to the site "FindItParts" and look under heavy duty truck parts, punch in "fuel tank" and page after page of tanks are available. Also Dorman and Spectra have tanks.
78buckshot #1513597 08/19/2023 3:07 PM
I’ll check it out, thank you.
Someday2023 #1513602 08/19/2023 3:35 PM
What are the measurements ?
hcb3200 #1513604 08/19/2023 3:50 PM
It’s 33” long 12” tall and 12” deep.
Someday2023 #1513636 08/19/2023 9:08 PM
So that is a 20 gallon tank.
If you just want to replace the tank and don't care if its model year specific. Then your hunt is going to be much easier.
Just look for 12 x 12 x 33 or even longer in length and you may find what your looking for. Or 20 gallon search and just compare dimensions.
The good news is you have plenty of room under for a different tank that can be close to that size and not necessary exact.
I could not find a good GM fit so just so happened my model year has a ford tank with dimensions I was looking for. Tanks a tank and I am not doing a true restoration.
Depending on budget you can find some nice ones online in 20 gallon range aluminum and other items. there are guys who will even custom build you one.
I found a web site that had tanks with dimensions easy to search but now I cannot find which site it is. Soon as I find it i will post it.
Someday2023 #1513674 08/20/2023 3:52 AM
Maybe one of these universal tanks will work if it doesn't need to be OEM...
https://www.tanksinc.com/index.cfm/page/ptype=results/category_id=133/mode=cat/cat133.htm
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
hcb3200 #1513685 08/20/2023 5:15 AM
That’s a great suggestion. I’ll just look for the size that will fit. I was just hoping I could find the one that would just bolt right in the same spot and not have to move anything.
Mike B #1513686 08/20/2023 5:18 AM
Mike B smile
It looks like at least one would work. Thanks for the site.
Someday2023 #1517442 09/15/2023 12:30 AM
I was literally looking for the same style tank for my ‘46. I got the universal U3 series Tanks Inc tank thru Summit Racing. Free shipping ! It looks like it will be a good fit
Someday2023 #1517966 09/18/2023 5:51 PM
I ended up going with the 39D tank, reshaping the original mounting brackets a bit, shorting the straps and changing sides. For what I’m going to use the truck for it works better on the drivers side.
Someday2023 #1517969 09/18/2023 6:36 PM
Looks good. Are you going to do anything with the filler neck it looks like it might be a bit interesting to fill or does the nozzle fit
1967 Chevy c50 327 w/ sm465 5000Ib front 15k 2 speed rear w/ 22k springs, single axle, hydraulic brakes
Thick Chevy #1518032 09/19/2023 1:21 AM
Eventually I will. I’ll run a curved filler hose up the the flatbed and put the cap up there. For now I have to pump it in out of 5 gallon cans always so it’s not a huge deal.
Someday2023 #1518186 09/19/2023 4:32 PM
Professional procrastinator
pm sent
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
Someday2023 #1521490 10/12/2023 2:50 AM
I have a friend that has a radiator shop. I take my tanks to him and put a sealer on the inside of the tank. Works well if is is not too rusty or leaking badly. If is is a small leak maybe a radiator shop could repair it.
1957. GMC F350
