1 members (Hotrod Lincoln), 73 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1513232 08/16/2023 3:46 PM
On my 59 panels truck 1/2 ton, I would like to replace
the original sway bar with a new one. I have a new one.
Has anyone done this and can tell me what to expect.
I am concerned about the shock mounts and the sway bar that runs under them now.
This is what I want to replace. Off another panel (58) Both the same.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Guitplayer #1513242 08/16/2023 5:19 PM
Looking more closely and looking at a 58 truck with this sway bar on,
the shock mount has a bolted plate underneath on each that hold in place the factory
sway bar and riveted frame mount for the pivot arm.
Looks like I can mount the new sway bar plate on the frame forward
of the riveted mount and mount the bar to the axle.
This kit
~ BD.
Guitplayer #1513250 08/16/2023 6:39 PM
Below is what I used on my 58, 3100. The kit was purchased directly from CPP, was easy to install and made a heck of a difference.
The kit you showed is in my humble opinion an AD series front anti-sway bar.
Dan
35 CC Case
38 Chevy Pickup
51 3100 AD
58 3100 Apache Fleetside
Guitplayer #1513263 08/16/2023 8:17 PM
Thats the same kit I used. It does make a difference!!
Just got it on and drove on some curves. Nice!!
All I had to do was cut 1/3 inch of the corner of the
shock mount. Here.....
~ BD.
Guitplayer #1513383 08/17/2023 5:36 PM
59 Apache 3100
59 Apache 3100
F Online: Content
The aftermarket kits are almost a bolt on . I 2nd that they make a night & day difference .
I believe I got mine here
https://www.classicparts.com/mobile/1955-59-Anti-Sway-Bar/productinfo/74-804/
1959 3100, original 235/3 on the tree w/overdrive. Carter YF 2100S carb, 205/75/15 w/front sway bar
Guitplayer #1513384 08/17/2023 5:55 PM
I can see from your pictures why you're called festerhairball.
1950 Chevrolet 3100 (Ol' Roy)
Guitplayer #1513390 08/17/2023 7:09 PM
Authorized Pest
Authorized Pest
festerhairball,
Wow. Thanks for adding info and arrows in your photos. I notice you've been doing that with most of the images you post. thumbs_up
Just wanted to mention that is very helpful (and impressive). smile
~ Peggy M
1949 Chevrolet 3804
Guitplayer #1513391 08/17/2023 7:09 PM
To add... there appears to be 2 different shock mounts.
One has a square end to accommodate the sway bar.
The other slanted. Hole for the shock is in the same location for both.
Maybe the diameter of the sway bar off high. Both my 58 and 59 panel trucks have the sway bar and the square end mount.
My 58 stepside has the slanted end version. I'm not sure if it came with a factory
sway bar or not.
~ BD.
Guitplayer #1513393 08/17/2023 7:36 PM
59 Apache 3100
59 Apache 3100
F Online: Content
Otto,
grin your post made me laugh. I have 2 small dogs that shed like crazy & they chase each other under the 59. Thus their hair is everywhere.
