8 members (rfs56trk, Frank50, BarryP, Gazz, UtahYork, Jon G, Ole49GMC, 1 invisible),
106
Mod | | | Forums66 Topics128,134 Posts1,056,740 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Neither RockAuto, nor the big parts retailers, list a drum brake hardware kit for a 1951 1/2 ton.
However, you can find them listed for early 60s trucks that wore identically-sized shoes. They look like the right parts to me.
Anyone know why this wouldn’t work? For instance the Carlson H7017 (same part number is used as retail house brand) looks to be a viable kit for the front.
1951 3100
| | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | Looks like it should work. I've bought lots of generic kits and they all seem to be the same thing...just sold under other names. Price doesn't look bad...$8 or so. That's about what I paid for the last one I bought and that was over 10 years ago.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Aug 2005 Posts: 278 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 278 | Looks to me like 11 by 2 drum Bendix hardware is basically the same from 51 thru 70 1/2 ton trucks. Exception would be self adjusters used around 63. Even this self adjusting hardware works fine on earlier years. Lots of the same stuff around on other sedans and trucks with Bendix 11 by 2 brakes. It is all the same. I have even used the brake hardware from a 67 1/2 ton chevy on the front of a 49 1/2 ton F***. (Respectfully referred to as a Chevy F1.) | | |
