1 members (UtahYork),
128
Mod | | | Forums66 Topics128,186 Posts1,057,318 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 36 | Just added my 47 2 ton flatbed to the February home page. It's titled as a 47 but as you see it looks like a 46. Can anyone confirm that it was in fact made in 47 sometime before march. All I have is the information on the body tag. It says 21PW-K and in smaller numbers behind that says 8115. I've never seen an actual date anywhere. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | It is probably a 47. The early 47s used the older body style at the beginning of the year.
Is it still for sale? | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Very nice truck. Do you have pics of before restoration? I like the deck, I have to make one for my 1948, which came from Seattle. Although, it was originally from Wisconson. Will your truck be at Shelton in August? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Apr 2004 Posts: 5,091 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,091 | Not sure if Mike "Burgandy Bolt" Allen will see this post, but he told me this about it:
I found some info on this as quoted from the "Chevrolet pick up red book" which gives history on, decodes serial #'s, colors options etc. The book states, the first series of 1946 Chevrolet pickup production began September 1st 1945, and continued through Sept 1st 1946. The vehicles produced during this period are known as "interim" models and are indicated as such by the designation ck in the serial #. Second series 1946 trucks were built from May 1st, 1946 to May 3rd 1947, and had a dp designation. You'll find some interim models titled 1945's and some second series titled 1947.
Hope that helps. Sounds like Stan's got a rare truck if his serial # checks out as per the above noted info.
So, if anyone can help clear this up, we can add the information to the Gallery page. In case it comes up again. Plus re-title it if need be.
Thanks, Peggy
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | ok dude here is what you have the vin for your truck is (21pw-k 8115) the break down is 21= plant where made janesvill wisconsin pw= 2 ton 160 in wheel base so it is a long box 2ed run k= mounth it was made k=11th month November 8115=the proudction # of your truck so it was the 8115 truck built of 8463 for that run in 1946 so yes if it was sold in 1947 it could be titled as a 1947 first serries all this info is recived from http://www.brads41-46chevys.com/
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | info can also be found right here  | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Originally posted by red58: info can also be found right here Man that works slickern' snot on a doorknob! Just punch in the number and just like magic, up comes the information.. and links to the corresponding years gallery, to boot!
| | | | | Joined: Apr 2004 Posts: 5,091 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,091 | You betcha!! It's good to see when they are working like that!
Excellent!
Peggy
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Apr 2007 Posts: 1 Junior Member | | Junior Member Joined: Apr 2007 Posts: 1 | HI,LOOKING FOR A 4 SPEED HEAVY DUTY GRANNY GEAR TRANSMISSION-I THOUGHT IT WAS A SM420 BUT IT IS NOT,THE BOLT PATTERN ON THE BELL HOUSING IS SMALLER THAN THE SM420-WHAT KIND OF TRANS DO I HAVE,AND WHO IT WAS MADE BY-THANK YOU VERY MUCH FOR YOUR HELP-KEEP EM ROLLING-46 2TON GUY-KARL :confused: | | |
