3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1512888 08/13/2023 10:41 PM
Trying to remove the head light switch from the dash of my 1959 gmc 100. I found the "secret button", where all the wires connect to the switch that allowed removal of the on/off/park lamp knob. I think the face bezel removal is the next step and it's really stuck on there and seems like a flimsy piece of thin sheet metal. I show it in the attached picture. The bezel is bluish silver. What should I focus on next to get the switch out from the back of the dash? Thanks, Dan
AD Addict & Tinkerer
It looks like the bezel is already damaged. I would use “a little” penetrating oil like Kroil, then wiggle the switch while applying slight pressure with a screwdriver. Don’t drench it as it might creep into the contact areas and I’m not sure what it would do.
If all else fails, use a vice grip then replace the bezel. You can buy them from Classic Parts here.
Phil
Project Journals
Stovebolt Gallery Forum
Hey Phak1, that link doesn't work for me. Is it working for you?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
B Online: Content
Worked for me.
Me Too.
Brian
1955.2 3100 Truck
Here is the address to copy and paste.
https://www.classicparts.com/1947-53-Light-Switch-Retainer-Bezel/productinfo/30%2D008/
Phil
Project Journals
Looks like it is failing the mobile redirect. In desktop mode it works fine, in mobile mode it errors out. Interesting.
It works for me on the phone and the desktop.
1950 Chevrolet 3100 (Ol' Roy)
