Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (MickeyP, Gdads51, Otto Skorzeny, Bill Hanlon), 48 guests, and 0 robots.
Topics128,007
Posts1,055,279
Members48,418
#1512739 08/12/2023 8:50 PM
Riding in the Passing Lane
I was watching Stacy David's show (Gearz) on the Motor Trend channel this morning. He is showing how to replace a dist. in a Jeepster. I believe it had an AMC V-8 engine.
After removing the cap & wires he picked the old one up & set the new one down in. "Make Shure it drops all the way down" which it did. I used to wish it was that easy.
24 out of 25 times they do not mesh with the oil pump without turning the engine. He did not say anything about lining up the position of the rotor.
George
1972 Chevy c10 Cheyenne Super
George,
Just a note that this better fits in the Engine Shop forum so I have moved it over there.
I think many of us have experienced the same thing (missed the mesh with the shaft) at least on one or more occasions. I known I have. dang
Dan
~ Dan
1951 Chevy 3 window 3100
I'm quite certain that the shows real mechanic had that all set up for Mr. David prior to the shot. I do like that show, Stacey is one of my favorite car parts hucksters. Just have to get him to do something about that hair.
Steve
Steve
1946 1/2 ton
It was not uncommon to get the gear clocked a tooth or more late, and have to rotate the housing to an oddball position to set the timing correctly. On the early Chevy V8s that could cut off oil flow to the hydraulic valve lifters on one cylinder bank, since the distributor housing had a flat spot that had to line up with the oil gallery for that side. If the plug wires and dizzy housing were clocked incorrectly, the oil gallery for the passenger's side could get restricted. Later models got a full groove around the housing instead of the milled area.
We'll file that under "As seen on TV."
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
