2 members (Steveoreno, Napco Man), 99 guests, and 3 robots.
Topics128,194
Posts1,057,263
Members48,466
So the other day I decide it's about time to change the pan gasket (my starting point for a whole bunch of maintenance and upgrades) on my '65 C20. Thought it would take a few hours. HA! Took 2 days! Mild pain in the arse it was. After accomplishing that, I installed my new headers, Offy intake and fabricated linkage for the new 2 barrel. Tonight, after everything's finally installed, I start to put fluids back in. I pour the shop manual specified amount of oil in and fill the radiator. After a couple minutes I check the dipstick. Nothin' there. Pour another quart and it's only just starting to show. Now I'm starting to wonder what's going on. This thing's got 5 quarts now and not full. Surely a 230 would be full with 5 qts. I go and look at the manual again. Hmmm, yeah, that's the right amount, should be full. A 292 takes 6 qts I noticed. I look in the front of the manual. I read that 4 and 6 cylinder numbers are stamped on the right side of the block just behind the distributor. I check my numbers. Holy crap! It's a 292! All this time I thought I had a 230 'cause the previous owner said that's what it was. I never bothered to check the numbers.
I'm pretty excited. Had to tell someone who'd understand the signifance. My wife said "So that's a good thing?".
Moral of the story: Just 'cause someone's sellin' an old truck doesn't mean they know anything about 'em or what they got! Ya gotta look for yourself. Yeehaw!
Tradin' up dimes for nickels...
My \'65 Chevy C-20
Congrats on your good luck. I bought a '71 GMC and was surprized to find a posi tag on the rear end. So I looked on the glovebox door and sure enough, it was factory installed.
Every 25 years I like to rebuild that 292 just for GP
Once bought a 1960 Apache20 which then-owner said had a 235or250. Didn't matter which to me 'cause it ran GREAT. Turned out after some research that the amazing power(hillcliming) came from 292.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
