| | | Forums66 Topics128,205 Posts1,057,425 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 251 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 251 | Dan, I know this isn’t the place, but since you mentioned it here, why don’t I see your signature line, nor my own? This is what mine should post as….. 1957 Chevy 3200 PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights
Last edited by Gdads51; 08/10/2023 3:00 AM. Reason: Title edit to begin a new thread in IT Shortbus
1957 Chevy 3200Daily DriverPS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights. Follow in the DITY | | | | | Joined: Oct 2021 Posts: 6,969 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,969 | DES57 I can see your signature line and Dan's.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2009 Posts: 6,047 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,047 | DES57, I went ahead and moved your post as a new question into the IT Short Bus to help get you an answer without messing up the original thread where posted. In my attempt to answer, the one thing that pops up in my mind is to ask " Are you using a phone or small tablet device to view and interact with Stovebolt?" If the answer is yes, try to change the screen orientation from long top to bottom view to sideways view (turn your phone on its side to change the aspect and display of the web page). For most phones I have worked with, looking at the web page in the vertical view shrinks the page and blocks viewing of certain portions of the web page (for example the left side panel and links doesn't display on my phone when viewed in vertical view but does show when switched to side view) you normally see on a laptop or full size computer screen. Changing the phone direction should change the page viewing characteristics, expanding the page to allow you to see the things that were being blocked from view in the vertical view. Hope this make sense and interested to hear your feedback after you give it a try.  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jul 2000 Posts: 2,208 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,208 | Go into your profile, preferences and change "show signatures" to "always".
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2019 Posts: 2,244 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,244 | Go into your profile, preferences and change "show signatures" to "always". The screen orientation still affects the signature display even if it is set to "always". | | | | | Joined: Aug 2019 Posts: 251 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 251 | Thanks Dan! Screen orientation was my problem. 1957 Chevy 3200Daily DriverPS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights. Follow in the DITY | | | | | Joined: Sep 2009 Posts: 6,047 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,047 | Glad to hear we were able to help! That orientation change helps access a lot of other page features you don't see in the normal vertical view mode. Enjoy!  Dan
