4 members (Wayne67vert, TexasA&M48Truck, Gdads51, Bucker), 76 guests, and 5 robots.
Topics128,212
Posts1,057,463
Members48,471
Dan, I know this isn’t the place, but since you mentioned it here, why don’t I see your signature line, nor my own?
This is what mine should post as…..
1957 Chevy 3200
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights
Last edited by Gdads51; 08/10/2023 3:00 AM. Reason: Title edit to begin a new thread in IT Shortbus
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
DES57 I can see your signature line and Dan's.
1950 Chevrolet 3100 (Ol' Roy)
DES57,
I went ahead and moved your post as a new question into the IT Short Bus to help get you an answer without messing up the original thread where posted.
In my attempt to answer, the one thing that pops up in my mind is to ask "Are you using a phone or small tablet device to view and interact with Stovebolt?"
If the answer is yes, try to change the screen orientation from long top to bottom view to sideways view (turn your phone on its side to change the aspect and display of the web page).
For most phones I have worked with, looking at the web page in the vertical view shrinks the page and blocks viewing of certain portions of the web page (for example the left side panel and links doesn't display on my phone when viewed in vertical view but does show when switched to side view) you normally see on a laptop or full size computer screen.
Changing the phone direction should change the page viewing characteristics, expanding the page to allow you to see the things that were being blocked from view in the vertical view.
Hope this make sense and interested to hear your feedback after you give it a try. wave
Dan
~ Dan
1951 Chevy 3 window 3100
Insomniac
Insomniac
Go into your profile, preferences and change "show signatures" to "always".
Gord 🇨🇦
1954 1/2 ton 235 4 speed
The screen orientation still affects the signature display even if it is set to "always".
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Thanks Dan! Screen orientation was my problem.
1957 Chevy 3200
Daily Driver
Follow in the DITY
Glad to hear we were able to help!
That orientation change helps access a lot of other page features you don't see in the normal vertical view mode.
Enjoy! thumbs_up
Dan
~ Dan
Moderated by  baldeagle, Gord&Fran
