| | | Forums66 Topics128,198 Posts1,057,272 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15125 05/07/2004 9:17 AM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | So the other day I decide it's about time to change the pan gasket (my starting point for a whole bunch of maintenance and upgrades) on my '65 C20. Thought it would take a few hours. HA! Took 2 days! Mild pain in the arse it was. After accomplishing that, I installed my new headers, Offy intake and fabricated linkage for the new 2 barrel. Tonight, after everything's finally installed, I start to put fluids back in. I pour the shop manual specified amount of oil in and fill the radiator. After a couple minutes I check the dipstick. Nothin' there. Pour another quart and it's only just starting to show. Now I'm starting to wonder what's going on. This thing's got 5 quarts now and not full. Surely a 230 would be full with 5 qts. I go and look at the manual again. Hmmm, yeah, that's the right amount, should be full. A 292 takes 6 qts I noticed. I look in the front of the manual. I read that 4 and 6 cylinder numbers are stamped on the right side of the block just behind the distributor. I check my numbers. Holy crap! It's a 292! All this time I thought I had a 230 'cause the previous owner said that's what it was. I never bothered to check the numbers. I'm pretty excited. Had to tell someone who'd understand the signifance. My wife said "So that's a good thing?". Moral of the story: Just 'cause someone's sellin' an old truck doesn't mean they know anything about 'em or what they got! Ya gotta look for yourself. Yeehaw! | | |
#15126 05/07/2004 10:18 AM | Joined: Jun 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 85 | Congrats on your good luck. I bought a '71 GMC and was surprized to find a posi tag on the rear end. So I looked on the glovebox door and sure enough, it was factory installed.
Every 25 years I like to rebuild that 292 just for GP
#15127 05/10/2004 1:53 PM | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | Once bought a 1960 Apache20 which then-owner said had a 235or250. Didn't matter which to me 'cause it ran GREAT. Turned out after some research that the amazing power(hillcliming) came from 292.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
