1 members (Otto Skorzeny), 87 guests, and 2 robots.
Topics128,052
Posts1,055,717
I recently replaced the fuel pump on my 46 2 ton for no apparent reason, other than i wanted a fuel pump that had a filter on it, rather than cutting and adding one in the line. Now that i have replaced it, it acts like its starving for fuel on the initial startup and stalls a couple times, Never had a problem until this, and I got it from a reputable parts supplier many know. Any ideas?
This is not sarcasm, if possible, put the old pump back on and see if the problem goes away. Many on here have commented that their "new" pump did not work well, worked for only a short time, or did not work at all. Beyond that can you tell us what engine you have and also what part number / model number fuel pump you installed? Pictures are really helpfull. There has been some discussions that "new" fuel pumps have an issue with the lever arm operating distance and that may be an issue with providing the volume required. Let know more about what you are working with.
Ron - - Dusty53
1954 Chevy 3604
H Online: Content
I'm considering trying to design an adapter and pushrod setup to fit a small block Chevy V8 fuel pump to a stovebolt engine. I don't know if those pumps will be any more reliable than the ones we're having so many problems with but they're certainly more available. and possibly less expensive.
Yes, it is a 235 in my 46. I bought a pump from a good vendor; it has the glass bowl with filter on top of it. I did look pretty close at it before I installed it, and it looked the same. I never had a issue until now, so yes, I tend to believe it's something with the pump. Maybe I need to put the old one back on? I will try to get some pictures!
When I had to replace mine on my 62-235, I ordered one on amazon and they sent me one for a small block V8. I when to two auto parts stores and they both handed me a fuel pump for a small block V8 and assured me it would fit. And of course according to the computers it would. Finally found a rebuilt NOS one on Ebay. No one makes new ones any more.
