5 members (55shaker, 49nut, ndkid275, Gdads51, Rusty Rod), 112 guests, and 3 robots.
Topics128,130
Posts1,056,367
Members48,441
I couldn't find this info on the sticky thread and it doesn't look like you can post to it anymore...
Can anyone tell me if the big 5 lug independent suspension (IFS) spindles/hubs are the same as the I-beam axle type?
If so that would be great as there would be more vehicles to choose from...but if I had to guess the answer is no, the type to find is from the I-beam.
1971 Chevy K10
1968 Chevy C50
1966 GMC 4000 Tilt Cab
Riding in the Passing Lane
The trucks with the I beam front axle never came in 5 lug hubs. The P30 trucks all have 8 or 10 lug hubs.
George
1972 Chevy c10 Cheyenne Super
George, I thought the P30 had 5 front and 10 rear...am I wrong?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I think there were both? I have a P30 with 16"wheels and it is an 8 lug. I had a P30 with 19.5" wheels and it was 5 and 10 if IIRC. I think someone posted once that they tried everything to replace 5 lug fronts on an I beam with something modern and never found a solution. So my guess is probably no...
Mike
George, thats incorrect. I bought a P30 with the I beam type, with the big 5 lug axle...so P30's do come in both 5/10 lug or 8 lug.
Trying to understand the differences on the spindle/hub between IFS and I-beam...
If I had to guess the disc brake P30 swap only works if you find the I-beam type since it uses kingpins.
That makes sense anyway...
1971 Chevy K10
1968 Chevy C50
Mike B smile
You are correct. The wheels are 10 hole but the front only uses 5 holes.
George
I had a 1999 Chevy 3500hd rollback with a 15000 gvwr and it was 5 lugs in front on an ibeam with disk brakes. The rear was 10 lug with disk brakes also. Used the same wheel front and rear.
the c3500hd front axle is very similar to the P30 front axle that are the I-beam type. But with the c3500hd axle the steering components are in front of the axle, while the P30 has the steering components behind the axle - which is how our old big bolt trucks have their steering. This is why Griggs recommends finding the I-beam P30 axles for disc brake swaps.
1971 Chevy K10
1968 Chevy C50
Crusing in the Passing Lane
My ‘55 GMC fitted P-3500 HD front disc brake hubs/spindles with tie rod behind axle easily without tires sticking out past the fenders, with new ($12.09) new king pin bushings.
Ed
