5 members (klhansen, UtahYork, 1955 1 Series, greenie-reddy, dt235sd), 210 guests, and 2 robots.
Topics128,085
Posts1,055,969
Members48,430
#1511392 07/31/2023 8:18 PM
I have one here but cannot seem to find so I`m looking for
this lever that fits over/clamps the clutch pedal linkage and the clutch adjusting rod
hooks to. Are they sold new?
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Guitplayer #1511725 08/03/2023 10:39 AM
Has anyone seen this before? Goes over this end.
~ BD.
Guitplayer #1511886 08/04/2023 12:12 PM
No one?
~ BD.
Guitplayer #1511892 08/04/2023 1:21 PM
I did some web searching since I am away from home and my hard copy books. frown
Couldn't find anything specific, most likely as can't figure out what GM used as a "name" for the part???
Any chance you can provide a large picture with more details of the "diagram" you posted as well as what book you got it from?
Will see if I can do more checking tonight if you can add more details.
Dan
~ Dan
1951 Chevy 3 window 3100
Guitplayer #1511903 08/04/2023 3:56 PM
No worries. I turned everything upside down and found it.
I`d like a look at the bolt however. Thats not there. Used to clamp
~ BD.
Guitplayer #1511911 08/04/2023 7:07 PM
Rustbucket Ranch
Rustbucket Ranch
I have one of those for my '58, I'll try to remember and snap a pic for ya.
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
Guitplayer #1512363 08/08/2023 4:49 PM
If I remember correctly it just uses a standard 3/8" bolt & nut. That one has considerable wear on the end where the clutch rod
attaches which can cause slop in the clutch operation.
Fred
Guitplayer #1512438 08/09/2023 1:41 PM
Rustbucket Ranch
Rustbucket Ranch
rfs56trk is correct, its just a regular nut and bolt with a couple washers.
Guitplayer #1512445 08/09/2023 2:09 PM
Nice. Thanks!! I ended up using a 3/8 carriage bolt SS.
The square shoulder snugged in perfect.
~ BD.
