3 members (Otto Skorzeny, Gdads51, 1 invisible), 137 guests, and 1 robot.
Topics128,109
Posts1,056,266
Members48,439
#151165 02/25/2007 1:14 AM
24601
Progress on the big '49! Today, my friend Gary (same Gary that helped me get the firetruck) helped me press in the new U-Joints and I was able to get the drive line reinstalled from the transmission on back to the rear axle.
It's starting to look like a truck again grin
Man, some of those caps took every bit of 30 tons to go home! Yikes.
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Good to hear your making progress. Hope all the needles are in place 30 tons seems excessive to me. I am thinking you smashed some bearing. Do they move smoothly?
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Yeah for the '49. Sure hope your helper didn't let a needle fall down in one of the cups...a good bench vise will easily seat a cap. Did all the joints flex nicely when the job was done?
Stuart
If there were burrs and paint it can take some force. Perhaps the gage is not reeding correctly, because it still sounds like a lot to me. If you were to drop a needle and then force things to go together enough to get the clips in you should see a dent or crack in the end of a cup from the needle trying to get out. I assume you would notice that, and you did not say anything about it, so the u-joints must be fine.
•1952 Chevrolet 3800 pickup
---All pictures---
Just when you were feeling good about it here comes a bunch of people to start you worrying. I, too, wonder why it took so much pressure.
Hi John,
Congrats on the progress; can't wait to see some pictures of the work.
I agree with the rest of the crew...30 tons to press on the end caps of a U-joint is very excessive. Heck, I've used much less taking old rusty ones off...
Not sure what everyone else does, but I always clean the shaft holes with a round pipe cleaner (like the plumbers use for copper pipe) and then check for any burrs. If any are found I use a small round file to remove the burrs). Then, after a thorough washing and drying I'll spread a thin film of anti-sieze on the shaft holes prior to installing the U-joints. It acts as a lubricant and also makes for easier removal when replacement is required.
Good luck and drop us some pictures!!!
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
[b]Burgie's 1964 Chevy C60 Restoration Site[/b]
Authorized Pest
Authorized Pest
John here (Too lazy to log out and back in)
EXCELLENT pointers! A dropped needle or two was what I was thinking, too. But the driveline rotates just fine now. So what I figure was that between a burr or two, and my sloppy painting with the POR-15, the couple of caps that gave us "issue" were just that -- recalcitrant rather than just plain frigged up.
Thanks for the feedback! I'm just glad we didn't crack/break any of the fittings.
Oh yeah, on the last one -- just as we were applying a bunch of pressure, it gave a mighty "POP!!!!!!" and seated. We thought for sure we busted it. We took it out of the mount and looked it all over and found nothing wrong so we figured it was a burr that I had overlooked.
All is well!
Thanks!!!
~ Peggy M
1949 Chevrolet 3804
John,
Great word....recalcitrant! smile
Stuart
Former Workshop Owner
Nothing beats the satisfaction you get from real progress. smile I'm starting to feel like Mick Jagger lately "I Can't Get None". grin I must have the winter blues, I might have to get me a motivational DVD. eek :rolleyes: Well, maybe not. grin
Great to hear your moving right along. Have you started the engine yet?
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
24601
John,
No, I have not made the first power up/ground run yet. My big accomplishment for the week so far is the reinstallation of the fuel pump and I put oil in the crankcase.
Yeah, I know, but that's how it goes. I'm pacing myself... I still have the manifolds to reinstall, carb, distributor and starter to go. The starter is still at the shop, I haven't remembered yet where I stashed the distributor and I'm waiting on those little rings that go in the exhaust manifold holes...
grin
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
