| | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | I have a 1970 C50 with 292 and monojet carb. There is a ball/socket joint on a little rod that connects the carb to the rest of the throttle linkage ( out of firewall). The rod does not stay on the ball, previous owner wired it on, not safe looking. what can be done to repair the socket joint or replace it? have not found any in junk yards. I'm guessing this rod is not available any where. rod is only about 2 inches or so long. :confused:
1970 C50 dump! saving orphans from the CRUSHER
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's an odd spring clip that is usually the "lock" between those 2 pieces ... if I find a pic I'll post it, someone else may have a name for it
Bill | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Yes, also looks like there is a sm brass cotter pin mabey holding the spring clip? looks like the spring clip is worn or damaged. coming up empty finding one here.
