4 members (rfs56trk, TexasJim50, Gdads51, Otto Skorzeny), 127 guests, and 3 robots.
Topics128,078
Posts1,056,024
Members48,433
I have a 1970 C50 with 292 and monojet carb. There is a ball/socket joint on a little rod that connects the carb to the rest of the throttle linkage ( out of firewall). The rod does not stay on the ball, previous owner wired it on, not safe looking. what can be done to repair the socket joint or replace it? have not found any in junk yards. I'm guessing this rod is not available any where. rod is only about 2 inches or so long. :confused:
1970 C50 dump! saving orphans from the CRUSHER
there's an odd spring clip that is usually the "lock" between those 2 pieces ... if I find a pic I'll post it, someone else may have a name for it
Yes, also looks like there is a sm brass cotter pin mabey holding the spring clip? looks like the spring clip is worn or damaged. coming up empty finding one here.
