1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1511052 07/29/2023 3:05 PM
I take that if there is any play in this pin the entire carrier will have to be replaced. 1/2 ton 1957.
sub57 #1511053 07/29/2023 3:16 PM
H Online: Content
Not enough information- - - -is the pin worn, or is the hole egg shaped? It would be possible for a really good machinist to line ream the carrier and press sleeves into it, but it would be cheaper to just buy another carrier. Back when automatic transmission "shift kits" were popular with people who didn't know any better, I saw several carriers with the pin hole worn oval by 1/8" or more. There was a good reason for the wear, which isn't really important to this thread, but it was a direct result of altering the transmission shift strategy.
sub57 #1511055 07/29/2023 3:26 PM
Let me get a better picture. Are pins available new like the bolt or is it a matter of finding them somewhere nos.
sub57 #1511057 07/29/2023 3:32 PM
H Online: Content
Try browsing Ebay for a new, or good condition used pin. The first thing to do is remove the pin and do some measuring with a micrometer- - - -NOT a dial or digital caliper. More than a few thousandths wear where it rides in the carrier is problematic. Once the pin starts hammering itself back and forth as the drive wheels encounter rough road surfaces, potholes, etc., the hardened pin will wear the softer metal of the carrier pretty quickly. Also measure the holes in the carrier for oval wear with a spring loaded expanding hole gauge.
sub57 #1511083 07/29/2023 5:30 PM
ODSS Lawman
ODSS Lawman
Correct me if I am wrong, but isn't the pin held in place with a bolt? Or is that older vintages?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #1511110 07/29/2023 8:33 PM
It is held in place with a bolt. In this case the axle shaft spacer seems to have play up and down and side to side. Have located new pin and block, will check the differential case holes. The side and pinion gears look ok. This is a napco conversion but I don't think that makes any difference. There a pic of the spacer block and pin,carrier old and new pinion. Don't get why this spacer has so much play. By looking at the date on the ring gear I think someone was in the old girls rump before. We have had the truck since1974 so it was before that date. The wear on the ring and pinion look good and the side gears and pinion gears are good.
