8 members (Ponchogl, Gabes-trucks, Wickedbass, Otto Skorzeny, 52Carl, dt235sd, BC59, 1 invisible), 138 guests, and 1 robot.
Topics128,081
Posts1,056,076
Members48,434
#1510382 07/24/2023 8:49 PM
New carb on rebuilt 235. idles fine but once I give it throttle it bogs down and the motor just doesn't pick up. Any ideas or tips appreciated. I tried to post video but won't let me
Justice #1510385 07/24/2023 9:14 PM
5 Online: Content
Check the gasket between the carburetor and the insulator, and the gasket between the insulator and the manifold (if you chose to use one there) to make sure that the gasket has a hole in it which corresponds with the hole in the flange of the carburetor and the hole in the insulator.
Justice #1510389 07/24/2023 9:31 PM
O Online: Content
What do you mean by "new carb"? What kind? Who made it? There are no new carburetors being made for these trucks that perform as they should. They're Fitzall units made in China that are meant to give so/so performance on a wide variety of applications but in reality don't perform well in any application.
Check the accelerator pump. Look down the throat while goosing the throttle and see if you see healthy squirts of fuel.
1950 Chevrolet 3100 (Ol' Roy)
Justice #1510397 07/24/2023 10:15 PM
Carburetion specialist
Check to make sure advance is working.
Jon
The Carburetor Shop
Justice #1510401 07/24/2023 10:39 PM
All excellent suggestions above. Easy things to check quickly. Also…
* Is this a stumble/ bog before acceleration that eventually smooths our? Or just a general refusal to pick up RPM?
* Are valves adjusted properly?
* How did you set the timing?
* Is the engine warmed up to operating temp when it displays the behavior you describe?
1951 3100
JW51 #1510407 07/24/2023 11:12 PM
General refusal to pickup rpm. I checked the carb gasket and it’s good. It did something with my Rochester rebuild so I bought this Chinese carb thinking it was my rebuild skills or lack off. The engine does this cold and warm.
Justice #1510415 07/24/2023 11:38 PM
Find the exhaust restriction and fix it. Begin by loosening the pipe at the exhaust manifold flange and checking for acceleration- - - -then move back one coupling at a time until it bogs down again. The engine is constipated- - - - -"Can't pass anything!"
52Carl #1510427 07/25/2023 12:28 AM
Checked and replaced gasket no change
Hotrod Lincoln #1510428 07/25/2023 12:29 AM
I will check in am and let you know. Thanks
Justice #1510480 07/25/2023 1:11 PM
You diagnosed your problem in this post.
Justice #1510533 07/25/2023 8:50 PM
Riding in the Passing Lane
Sounds like the timing might be real slow. Try advancing the spark timing & see what happens.
George
1972 Chevy c10 Cheyenne Super
