6 members (37 GC, klhansen, Shade Baby, Reftys49, MaxStewart, Philipj), 95 guests, and 1 robot.
Topics128,143
Posts1,056,786
Members48,454
Does the carrier have to be removed to replace the seal, or can it be accomplished from the exterior of the housing after removing the u joint?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Cutaway drawing makes it look like it can be removed from the outside.
I replace my dana 44 seal. Just pull the yoke. Do not use an impact driver. Buy a new yoke nut SPICER 30271 . You will need a 250 ft. lb. Torque Wrench.
Torque is 200-220 ft.lb.
H Online: Content
If you want to do it right, get a new crush sleeve that goes between the bearings and set the pinion bearing preload torque to the right specification by tightening the pinion nut a little at a time and checking the rotation torque with an inch-pound wrench. I believe the specification for used bearings is around 20 inch pounds. Remove the drive axles for the best torque check.
The Dana 44 and 60 use shims.
Spec
