2 members (68ironhead, stlcardinalsguy), 187 guests, and 14 robots.
Topics128,078
Posts1,056,036
Members48,433
#1509804 07/19/2023 9:26 PM
I followed the tech guide and made a chart. Now can anyone tell me what it means.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
What is the chart? Which wires are connected in which switch positions?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Doug,
Is this the "...tech guide..." (Turn Signal Tech Tip) you are referring to???
If so, have you read the descriptions below the 3 sample charts to understand what the marks mean using the "continuity" test results in your charts?
The marks indicate wires that have continuity (for lack of a more detailed description a circuit for each light fixture/component) depending on the position of the switch (Off/Left/Right). I think to make sense of it all, you need to identify which colored wires you have listed go to which component and then you can hopefully correlate if each circuit is correctly wired.
I'm certainly no expert in this and hopefully another member may be able to better explain what you have.
Dan
~ Dan
1951 Chevy 3 window 3100
.. and it wouldn't hurt to identify what kind of turn signal switch you are working with. Signal Stat 900 (or one of it's many clones), stock GM, etc.
Sir Searchalot
Sir Searchalot
T-Doug.....Hopefully you are testing just the turn signal with NO wires hooked up to anything except to continuity tester. I am following your charrt. I see you crossed out a few things as you went. Shows you were making mistakes. Chart seems like it is not right. (of course it is possible switch is no good, we will see)
1. Make a new chart. Draw on new paper. Don't look at old chart.
2. Don't revise the old chart. Leave it on here.
3. Post new chart and I will go over it again. List the colors the same way as old chart.
You are doing fine, just be more carefull. I see you used the word "neutral" instead of "OFF". That's OK, you are saying lever is in the middle.
Tripple check your work. If wires are faded, be sure Pink, Purple, BLU and GRN don't get confused. Your chart shows this confusion. Look at colors of wires in a place where they have not been exposed, like inside bell.
From pics I see it may be a "factory" original optional turn signal. pix
If original: Use this and consider GRN as LT BLU
LT BLU...........LF
YEL...................Flasher Input
DK BLU..........RF
Purple................RR
Pink.............LR
WHT..................Brake Switch Input
Twist wires together with wire nuts to test.
I’ll redo the chart later this afternoon. I’ve got a couple more items to work on before I go for a shower. Lunch first.
This is the factory option with an after market replacement switch that looks the same.
1954 Chevy 3100
Montgomery, AL
In Project Journals
That appears to be a stock switch. I drew the diagram below when I was troubleshooting one in 2006. The switch is shown three times. Top one is with the switch "off", ie. in the middle position. The second is with the switch signaling a right turn and the third is signaling a left turn. The black dots are the fixed contacts in the switch and the yellow pieces are the sliding contacts.
Sir Searchalot
Sir Searchalot
When I zoom up, looks like there is a LT BLU. Not GRN.
May be quicker to temp wire it up than make a chart. The colors on the switch don't have to match truck wire colors to sockets.
Use the info given by Bill and I to test.
Use wire nuts or non permanent method at first. This will also give good access for voltage testing if necessary.
Pretty sure this will work:
LT BLU...........LF
DK BLU..........RF
Pink.............LR
Use a 5A fuse for power to flasher.
Big shout out to Bill and Bartamos.. used the suggested connections and everything works... except the brake switch is bad...crossed the connections and brakes came on so happy days here.
Thanks for all the patient help..
Now on to upolstery... that will be in the journal going forward.. smile
1954 Chevy 3100
Montgomery, AL
In Project Journals
