2 members (klhansen, 59 fleet),
130
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 134 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 134 | Got my title from seller and the first number is a 7. I’ve looked and there is no # 7 assembly plant. Could this be an miss typed at mva ?? Confused
| | | | | Joined: Aug 2017 Posts: 671 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 671 | What numbers are on your V.I.N. plate? Was it titled to your Engine?
Can the "7" be a 2 ?
1950 Chevy 3100
| | | | | Joined: Oct 2021 Posts: 6,929 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,929 | The title for My Cadillac starts with an "S" instead of the "5" that it's supposed to be. DMV people mistype titles all the time.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2004 Posts: 6,232 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,232 | Does your new title match the tag on the truck? What's the first number on your tag? What info did you send to the DMV for them to process your new title...was the info you sent in wrong or did they type it wrong? Mike B  | | | | | Joined: Dec 2011 Posts: 134 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 134 | 7 is on the title. There is no serial # plate. I believe that it was a mistake by previous dmv people. So I will just go head and try to register it in my name and see if my dmv excepts it. | | | | | Joined: Dec 2011 Posts: 134 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 134 | I believe this is the case. Thanks | | | | | Joined: Aug 2017 Posts: 671 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 671 | Is your truck missing the V.I.N. plate? Do you know where it should be mounted? Todd
1950 Chevy 3100
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | 7 is on the title. There is no serial # plate. I believe that it was a mistake by previous dmv people. So I will just go head and try to register it in my name and see if my dmv excepts it. I would recommend doing this and just not say anything about it. Telling them that you think there was a mistake will just invite further scrutiny that you likely don't want. | | | | | Joined: Oct 2021 Posts: 6,929 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,929 | I agree with Fibonachi. When I went to register my Cadillac after purchase and asked about correcting the mistake on the title, the lady at the DDS counter warned me against doing it. It's a can of worms you generally don't want to open
| | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | flattop49, Just a note that whatever municipality issued the title you received from the seller technically had to use something on the truck to legally identify the truck. The missing ID plate could become an issue during your re-title process. Regardless of any other folks experiences given, the only entity you must rely on for titling your truck is your own state DMV. Your state laws and regulations are the only ones that directly apply, and that you must follow to satisfy the titling requirement. You should also be able to go online and read up on your DMV's requirements and rules that apply to title transfers and correcting title errors if such exist. Good luck and let us know how your title situation gets worked out.  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
